94 metro xfi problems; need help
Topic Started: Nov 27 2011, 06:36 PM (390 Views)
jmzmailforme
I had replaced a timing belt and a pcv valve as well as a tps sensor.Now I have white smoke coming out of my tail pipe along with moisture.Also experiencing hard starting .Once the vehicle is started it will bogg down and die out. Then it is really hard to get it to start up again. Any thoughts on this. :banghead
Welcome to your new forum, jmzmailforme! :coffee
Set the TPS with this link:TPS report.
Might have to go back and reset the timing belt because it may be a tooth off. Check your ignition timing.
How are the spark plug wires and other connections? Is the Check Engine Light on?
Jittney
Welcome to the forum, jmzmailforme :coffee
Did the problem start right after the new belt, or was it a gradual thing?
