Where to get a rebuild kit...specifically: rings pistons and bearings... and head shaving ?; just did a head job... and now i need rings!
Topic Started: Dec 10 2011, 09:11 PM (995 Views)
merlot566jka
Engineer
Just as the title says, where are you guys getting your re-ring kits? Quality, pice
and shaving the heads... how much nets what CR?
Thanks.
:popcorn
I never had to shave a head yet, but I get rings and bearings from AutoZone or Napa and those and other rebuild parts can be found at partsdinosaur.com
Eric J
Formerly CEJ93
You may want to take a look at Parts Dinosaur. I have read quite a few posts here where the people rebuilding stuff have sourced their stuff from them.
http://www.store.partsdinosaur.com/cgi-sc/productsearch.cgi
merlot566jka
Engineer
got it, thanks guys
mrcansian
What is the part number for the rings at autozone, I called autozone and they said they don't have any engine internal parts.
Thank you
mrcansian
Dec 12 2011, 12:23 AM
Thank you
What are you buying rings for?
crankcase
Ask to talk to someone that's got the GED :lol .
The Zone :shake , I once talked to a series of people that did not know what valves were!?........ engine valves.......not PCV .........what kind of valves? :smackface ........ :shit
About the third guy knew what I was talking about.
Maybe they don't carry them any more, but I do recall buying a set about 3 years ago.
95 metro G10 3 cylinder rings
http://www.autozone.com/autozone/parts/Sealed-Power-Piston-Ring-Set/1995-Geo-Metro/_/N-j1hutZ8zndi?counter=1&itemIdentifier=207773_115669_15997_10688
same rings at rock auto
http://www.rockauto.com/catalog/catalog.php
merlot566jka
Engineer
ordered rings, gaskets and valves and head bolts from partsdinosaur.com, 170.65 shipped. You cant beat that!
Wow! I must have bought every piston ring set and rod bearing set from AutoZone. Now they are out of stock and not available :rocker
