g13 --will a 96 bottom end fit a 99 head?
Topic Started: Dec 10 2011, 09:19 PM (439 Views)
Today i bought a g13 from a 95/96 4cylinder. I only need the bottom of this motor. It is an 8 valve.
I am going to put my 16 valve head on this bottom end.
Will my head bolt on?
Will i need to trade out belt sprockets?
Can I use any old g10/g13 rings or does the 16 VALVE piston take a special ring size?
Sinequa
Useless Twit
Bad move sorry :( you’ll need to swap out the con rods and pistons. The 8 valve has a different sized wrist pin and valve reliefs are nowhere close and only half there :). Learned this the hard way like you. crank journals are the same however
Edited by Sinequa, Dec 10 2011, 09:39 PM.
Thanks. i have the 16 valve piston with rods attached. just wondering about the rings.
Sinequa
Useless Twit
The rings are the same something like 1.5mm, the crank sprocket is different, the 16v has 8 teeth and 8v has 4 iirc. But that would depend on which ignition you use. With a distriutor it would be the 4 for the top coil 8. Yes the head will bolt right up.
Edited by Sinequa, Dec 10 2011, 10:04 PM.
