| Crankshaft cleanup | |
| Tweet Topic Started: Dec 13 2011, 12:38 AM (792 Views) | |
| mrcansian | Dec 13 2011, 12:38 AM Post #1 |
Hi, I'm rebuilding my G13 engine 1.3 - 16V , I cleaned all the parts, block, and everything , I only need to clean the Crankshaft to remove all the carbon deposits, I'm afraid to put degreaser ( purple power) on it and water. The water will rust the crankshaft Journals ? What is the best way to clean it and make it come back to metal ? Thank You.
| Memphis metro | Dec 13 2011, 08:46 AM Post #2 |
You ask for the best way so that is what I am going to give you. Take it to a machine shop and let them vat it and polish it for you. |
| bansheetaz | Dec 13 2011, 11:06 AM Post #3 |
use degreaser till as clean as you want. then rinse with water..... blow dry. spray with WD40. install when ready... |
| Tofuball | Dec 13 2011, 11:11 AM Post #4 |
Strange Mechanic
Best: Vat\Polish as enginedoctorgeo says Good: Carb cleaner and pad Bad: Forgetting to blow the oil holes out when you're done |
| bogs | Dec 13 2011, 12:08 PM Post #5 |
1:57 PM Jul 11
