Will a cluster with a tach from a 96 with 3 cyl work in a 92; Interchange with a speedo cluster
Topic Started: Dec 13 2011, 08:44 PM (800 Views)
Bigr2009
Ok my friend is about to scrap a 96 and it has a tach instrument cluster. I am wondering if this will work in my 92
mjspiess
What: Instrument Cluster with Tachometer & Tripometer
For: '92-'00 Metro 1.0 3 Cylinder
Donor Car: '92-'00 Geo/Chevy Metro LSi 1.0 3 Cylinder
Modification required: None. Although it may be beneficial to pull the speedo cable from the donor car as it is a little longer & double check the "idiot" lights, since the features of each car may be different. Example: Rear Defrost, etc. Also, be sure if your Metro is a 3 cylinder, you are pulling the cluster from a 3 cylinder & vice versa for a 4 cylinder. '89-'91 instrument clusters are shaped differently & will not work for the '92+ Metros.
Why: Able to see engine RPM & track mileage easier by using the tripometer, rather than doing math at each fillup :)
http://geometroforum.com/topic/3946668/1/
