Curse this alternator belt!
Topic Started: Jan 2 2012, 09:06 AM (8,878 Views)
FLINT
perfect thanks!
and the weather is warming up here (from a high of 20 on tuesday) to the 50s this weekend so I won't mind working oh the car as much.
Gizmo
I'm adding a quick important note. Just replace the belt instead of retightening over and over. I tightened mine, real real tight and lost about 10mpg! Best advise is to simply replace the belt. And at 15 to 20 bucks it shouldnt be to hard.
Jittney
Gizmo
Nov 5 2012, 11:57 AM
:hmm that's interesting....and thanks for chiming in.
GeoFlyer
Air Junkie
All,
I know it's a little different on my custom aircraft G10, but alternator belt squealing STOPPED once I installed a battery switch that I used to disconnect the battery when I wasn't flying, so the battery wouldn't drain down too much if 3 weeks went by without flying. A partially drained battery can result in additional load, resulting in the belt squealing. If you have a ground fault somewhere in the electronics, it could put your car in this situation where it always has a high starting load until the battery gets charged up a bit. And as it grinds up the belt, the belt will need to be retightened, etc.
mjspiess
I picked up this alternator tensioner. You can get them from an '88-'92 Ford Probe/Mazda MX6/Mazda 626:
Compared to the OEM one which is so lame... After I bent it to shape, cut out a notch to fit around a water pump bolt & drilled a hole for the alternator guard (still need to tap it). It's just zip tied for now.
You just need to get a little "S" bend in the bracket. It's tough thick steel, so it takes some pounding with a heavy hammer.
No more squealing alternator/water pump belt...EVER! :thumb
PA.metro,fixer,frames,ect
Frame Fixer
Nice upgrade.....
