| Sell the beast? | |
| Tweet Topic Started: Jan 13 2012, 10:46 AM (1,329 Views) | |
| vr4 | Jan 13 2012, 11:26 PM Post #16 |
I posted what I would do the job for but I would also charge a little for the drive. |
| Coche Blanco | Jan 13 2012, 11:31 PM Post #17 |
If the frame horns are solid, pay VR4 to do it. |
| Horn | Jan 14 2012, 12:06 AM Post #18 |
Yea like cb says if frame horns are good then it is worth it....also how do you know it needs all this right now? The cv shafts can last a little while with the slight click. Also any car around 1000 will need some kind of maintenance costs like brakes and gaskets...they will also have higher miles meaning wear on the engine. These cars have dependable engines and transmissions. And if yours has solid frame horns and the body isnt trashed then you should have a car that will last you a while...plus you can get any better mpgs and parts are cheap as hell for these cars. Dont sell |
| vr4 | Jan 14 2012, 12:10 AM Post #19 |
Here in washington the frame horns are always solid
| Woodie | Jan 14 2012, 07:33 AM Post #20 |
The original clutch lasted 18 years, no reason to think the replacement would not last 10, no matter how you drive it. 150K is a perfectly reasonable expectation from a clutch. |
2:15 PM Jul 11
