Smashed spark plugs; 1999 Chevy Metro
Topic Started: Jan 19 2012, 12:03 AM (2,886 Views)
mcmancuso
These engines like the NGK's I run the coppers with no problems.
ChevyMetro
undgsx-R
Jan 20 2012, 05:18 AM
Where are you in the midwest, if you are close I may be able to help you out with this car. Or I might be interested in it if you don't want to fix it.
I am in La Crosse WI, Where are you?
TimmyD
A Metro Driver
...I don't know your situation, but even if you have to drop a few hundered bucks into getting it back on the road it would be worth it. It might not be as bad as you think - pull the heade & see what your are dealing with before just giving up.
The only used cars out there that is compatible with the mpg of a Metro that is reasonably priced would be maybe a VW Golf (and it would probably have +100K miles on it)
Just my opinion.
gerrygrit
Read an article where they estimate gas is going back to over $4.
a gallon this spring..........fix it.........
The oil companies are going to ruin the economy yet..... :drool
ChevyMetro
Yea that is true about mpg
What years of the "GEO" are compatible with this?
Well I may keep it but maybe fix it in the spring idk Anyone Near La Crosse WI that would be willing to help?
Edited by ChevyMetro, Jan 20 2012, 11:52 AM.
ChevyMetro
whats a fair price if i where to sell it
iBLKBRY
Let's do some physics. The piston should travel the same distance away from the spark plug no matter the timing. If you have one cylinder with zero compression, you could suspect a broken valve tumbling about the combustion chamber and interfering with the plug. The second cylinder that is smashing the plug either has 150, or 180 compression as you stated which tells me that the valves are intact and the piston has changed its course, either by a stretched rod, wrist pin, or failed crankshaft bearings. My fathers metro engine failed to the point where you could grab the balancer and move the crankshaft up and down. This was a 1.3L in a '97 with very regular oil changes.
what part of the midwest? Geo Glenns got a motor for sale :D
http://geometroforum.com/topic/4649511/1/#new
1DCGUY
Don't be a "Richard"
ChevyMetro
Jan 20 2012, 09:56 AM
I'm located about an hour away from you, in the Rochester area.
PM me if you need some help, or if you want to let the car go, I might be interested.
c140flyer
How long ago were these plugs changed? Not to be a jerk, but it's possible that something fell into two of the holes while you had the old one's out. If you had enemies,that would be a great way to sabotage a car! ^o)
ChevyMetro
Jan 21 2012, 07:51 AM
what does he want for an engine?
Edited by ChevyMetro, Feb 22 2012, 01:31 PM.
ChevyMetro
1DCGUY
Jan 21 2012, 08:23 AM
ChevyMetro
What would you give me for the car? Also if I do decide to fix it, i may need help!
Grabbed this from his thread ''$850 exchange. I will deliver it for Geo Metro gas money. If you're nice, have a warm place to work, and let me camp out in your driveway, I'll consider helping install it. "
Edited by Scoobs, Feb 22 2012, 01:54 PM.
1DCGUY
ChevyMetro
Feb 22 2012, 01:32 PM
1DCGUY
ChevyMetro
PM Sent :)
