Micro van in San Antonio; on Craigslist
Topic Started: Jan 20 2012, 11:52 PM (1,914 Views)
Welcome to your new forum, Viv! :coffee
It depends on where you get your 12" tires. Actually my local Bruneel tire has the heavier 12" snow tires for about $70 each. So you will want to investigate getting 13" wheels, say from a junk yard, so your next purchase might be less painful. I'm sure some members with more tire experience will suggest something for your rig.
And congrats on getting your new toy. :thumb
Viv
Thanks, you can get 13 inch tires at Walmart, but not 12 inch tires. I was in a bind, and needed tires. Definitely going to do a wheel upgrade for the next set of tires.
Viv
Progress is moving slowly... Currently removing the vinyl graphics. Side molding has been removed. Found out that it started life as a four door model. Does anybody have a gas line diagram? Found some disconnected gas lines by the tank. It has a slight miss, already changed cap, rotor, plugs, wires. Runs rough after gas fill-up. Got fuel filter and PCV valve to change.
Run a compression test. What do you plan on using this thing for?
Viv
A clown van...
Nice! since it was a 4 door, if you need some parts for that 4door you might want cheaper than new i might have some of what you might need later on down the road.
