| Back in a Metro shortly | |
| Tweet Topic Started: Jan 28 2012, 11:38 PM (1,743 Views) | |
| bogs | Jan 30 2012, 12:20 PM Post #16 |
I thought it was only required that they be unsprung, not required that they be new? I might be wrong on that one though
| maxmpg | Jan 30 2012, 12:38 PM Post #17 |
Check this baby out: http://seattle.craigslist.org/oly/cto/2815659192.html It's a 5 speed, $800 but is in really good mechanical shape with lots of stuff already done to it. It's a bit of a "beater" cosmetic wise, but hey it looks like it runs great! |
| honestabe | Jan 30 2012, 01:31 PM Post #18 |
what do you mean by unsprung Bogs? both airbags have been deployed. |
| 68custom | Jan 30 2012, 07:27 PM Post #19 |
I think he means they have been deployed. |
| allmountain40 | Jan 30 2012, 07:41 PM Post #20 |
What BOGS meant was when you take it to state patrol you just have to have airbags in it that have not been deployed, not necessarily new. Unfortunately I am not that up on Washington airbag law, but it might be worth asking if you just have to have non-deployed airbags or if they have to be certified new. |
| vr4 | Jan 30 2012, 07:53 PM Post #21 |
I'm pretty sure used is fine. Have to have receipt for them though. |
| bogs | Jan 30 2012, 08:34 PM Post #22 |
Yes, what they said, I am not aware of any state that requires they be new, just undeployed, i.e. working or never been used. YMMV, though, your states requirements may be different. |
| honestabe | Feb 4 2012, 04:36 AM Post #23 |
I just picked up a 95 3/5 hb with 150k miles on it for $1500. The 2nd gear syncro's are bad, it needs a tune-up, and has low compression (130 psi across the all 3 cylinders). I suspect the low compression is due to built up carbon. Nothing a good Seafoam treatment can't fix eh? |
| Woodie | Feb 4 2012, 10:03 AM Post #24 |
Built up carbon will raise compression. Seafoam can't do anything about worn down metal. |
| honestabe | Feb 4 2012, 11:02 AM Post #25 |
ah well, I'll do some maintenance on the car and see what happens. Gonna change the trans fluid and a few other things this morning before I head down to pay it off. I'm sooo not looking forward to doing another DRL bypass. |
| vr4 | Feb 4 2012, 11:55 AM Post #26 |
Why? It takes less than a minute... |
| honestabe | Feb 4 2012, 11:15 PM Post #27 |
the last time I did it it took me an hour because I was confused about the wire colors (I'm partially color blind and the colors were faded) |
| vr4 | Feb 4 2012, 11:44 PM Post #28 |
Got it. Ill get you a pic of my 96 at the connector so it should be easy. |
| honestabe | Feb 5 2012, 12:07 AM Post #29 |
I think I went off a similar pic last time and still ended up being confused (but got the job done right). |
7:53 PM Jul 10
