| geo metro whine idle | |
| Tweet Topic Started: Feb 11 2012, 03:15 AM (1,181 Views) | |
| joseph1967 | Feb 11 2012, 03:15 AM Post #1 |
so im working on a 1999 chevy metro 1.0 and it seems to have a strange whine at idle and even when given gas i own a 1992 geo metro and it doesnt make the same sound on the 1999 i began doing a good tune up timing belt,water pump,crank seal,etc... well i ran the motor with no alt water pump hooked up no belt just timing belt and the motor still has that whine i'll make a video of it but is that normal for a newer geo? |
| joseph1967 | Feb 11 2012, 03:23 AM Post #2 |
the idle sounds alot like how this car idles http://geometroforum.com/topic/2255746/1/ its rather noisy and i was wondering why my 1992 sounds nothing like that |
| Car Nut | Feb 11 2012, 03:39 AM Post #3 |
Probably got the timing belt tensioner too tight. |
| snowfish | Feb 11 2012, 04:31 AM Post #4 |
The timing belt cover could be rubbing too.
| Car Nut | Feb 11 2012, 08:47 AM Post #5 |
Yep, could be that too. |
| wizard 03 | Feb 11 2012, 10:22 AM Post #6 |
I would bet its the timeing belt too. Put mine together and it had a whine too, but I knew what it was and dismissed it imediatly. You need to take a look at the timeing belt to ensure there are no problems with it and to ensure everything is ok, but if no problems are found {belt showing signs of wear, looseness, or fraying} then I would say to leave it alone. A little too tight won't hurt nothing and the belt will wear itself in and the whine will disapear eventually. |
| me2 | Feb 11 2012, 01:02 PM Post #7 |
An "idle whine" - I thought this was going to be a marital thread. |
| joseph1967 | Feb 15 2012, 10:49 PM Post #8 |
yes i ran the car with everything off just a timing belt on and a new idler pulley and no matter how loose i did it the car still seemed to have a whine but now its starting to fade away slowly sure was annoying to listen to made the car sound like it almost had a turbo lol
3:37 AM Jul 11
