| quick question about engine capability | |
| Tweet Topic Started: Feb 16 2012, 09:50 PM (516 Views) | |
| AmericanTrash | Feb 16 2012, 09:50 PM Post #1 |
i found a 93 engine with no ac/accessories, would it work with my 98 with no ac? |
| sphenicie | Feb 16 2012, 11:31 PM Post #2 |
The long block should be fine, you will need to use your externals. pulleys, intake, etc, as far as I know, 95 is the newest i've owned, but long block should be good to go. Someone will correct me if I'm wrong. |
| Scoobs | Feb 16 2012, 11:35 PM Post #3 |
youll also need to swap the pan, the oil pump, gasket for the oil pump, crank sensor, and youll also have one less a/c compressor bolt hole. |
3:37 AM Jul 11
