| Dropped key in flywheel. | |
| Tweet Topic Started: Feb 17 2012, 04:28 PM (1,422 Views) | |
| Memphis metro | Feb 17 2012, 09:55 PM Post #16 |
He was refering to the crankbolt comming off fine I believe. |
| Woodie | Feb 18 2012, 06:43 AM Post #17 |
THIS Only two bolts, right? |
| Memphis metro | Feb 18 2012, 06:50 AM Post #18 |
If it fell on the opposite side of the flywheel, looking thru from the inspection plate side, there may not be enough clearance between the flywheel and bellhousing to pull them past the flywheel. Depends on where it fell. |
| vr4 | Feb 18 2012, 04:39 PM Post #19 |
maybe....
| wizard 03 | Feb 20 2012, 01:53 PM Post #20 |
In the future, you may use a rather large and hardened screwdriver. I used one on mine where it wasn't small enough to fit into the bell houseing, but most of the tip fit in. That way if it broke off while I was undoing the torque converter bolts and crank sprocket bolt, I could still wriggle the tip out. At this point in time, I strongly suggest fishing through the starter hole with a magnet |
| Mattaboy | Feb 20 2012, 04:13 PM Post #21 |
Hey! I've been there. What a pain in the rear....I ended up pulling the engine loose to get the part out. I didn't think it was worth the risk of leaving it in there. |
3:35 AM Jul 11
