Geo Won't start
Topic Started: Feb 18 2012, 01:20 PM (3,438 Views)
charlesufarley
Grease monkey
A coolant temperature sensor that is reading too cold will cause the ECM to command too much fuel, a possible cause for your no start.
Vaultgirl
Thanks Woodie for the reply, but I have checked everything else except head pressure in each cylinder, from my searches on the forum (and personal experience) a decline in head pressure will not make your engine die while driving it. I'll try any advice I can get.
Vaultgirl
charlesufarley
Feb 19 2012, 02:38 PM
Checked- working fine. Thanks
wizard 03
Ok, from what I have seen, you have checked everything but the ignition. If you have fuel, if timeing is "sort of close" {hell, sometimes if it is way off} You should have fire somewhere! Unless something was wrong with your ignition, you should have fire inside the engine, in the exhaust, or in the intake.
To test the ignition, simpley take out a spark plug, ground the spark plug with a reliable ground, then turn the engine over while watching the spark plug for spark.
I use a really long spare sparkplug wire, and a long wire with aligator clips to ground the spark plug to the battery terminal. This way while Im cranking the engine over in the cabin, I can watch the spark plug.
If you have ignition, "and the plugs are at correct gap", I strongely urge you to try unplugging the injector, and trying to use your own fuel. Just dribble 4 table spoons of gas into the intake, keep the accelorator wide open, and crank for 30 secounds. If your ignition is correct, you will have fire somewhere.
In the intake, timeing is advanced or off overall.
Fire in the engine, timeing is close or spot on.
Fire in the exhaust, timeing is retarded or off overall.
Mr. NeoGeo
Ok folks...
*GULP* (that was my pride) :shake
I was not reading the timing correctly. At a closer inspection of the crank pulley, I noticed that there where 2 white marks. So, when I was using the timing light, it only appeared to be correct. :smackface
I took the timing cover back off and the timing was off by a few notches. I adjusted them to the correct positions and zoned in with the timing light.
Lesson learned.
I want to sincerely thank everyone for all the suggestions and help that was given. Thank you all for your support.
I have to give props and many thanks to Tracer from justanswer.com. He is very knowledgable and was able to help solve my problem even though I kept telling him the timing was correct... :ermm:
Mr. NeoGeo
Feb 20 2012, 04:22 PM
OUCH!!! THAT HURT!!!! Go back and check post #2 in this thread and see that DAYLE 1960 told you to recheck your timing.-----then go ahead to post #6 and see that I told you that no matter how much it hurts you to re check your timing.
Still you didnot belief us and AFTER 18 POSTS you had to go outside to find someone to compliment on helping you find oput your timeing was screwed.
WOW, JUST WOW!!!!!!!!!!!!!
Edited by Old Man, Feb 20 2012, 04:47 PM.
Georgboy31
Lol!!!! He thanked all of y'all!!! What do y'all want ? Trophies? Be humble guys...
Georgboy31
Feb 20 2012, 05:06 PM
where
Georgboy31
Right here: I want to sincerely thank everyone for all the suggestions and help that was given. Thank you all for your support.
Georgboy31
Feb 20 2012, 05:46 PM
Yeah, I guess Mr. NeoGeo needs some help getting out of this one.
wildhair
No worries you already swallowed your pride, admitted your mistake and thanked everyone for all their help.
I think there is no other option but to "kick yourself in the nuts" ^o)
Just kidding :whistle
The main thing is your back on the road, with the help of some pretty good folks.
As for the timing issues dont sweat it, happens to the best of them thats how they know.
Georgboy31
Be humble guys...
What's that?
Feb 21 2012, 06:21 AM
Georgboy31
Be humble guys...
What's that?
That is what someone who has never had the bit in his teeth will never have to worry about ;)
I'm happy to hear your car is finally working again, congratulations :)
Wow. For one day I am the smartest person in the room.
Hopefully next time Mr.NeoGeo will realize sometimes we know what we are talking about. Glad this is a lesson learned for you. Hope this lesson will continue to stay with you on your lifes' journey. Have a blessed day.
Vaultgirl
Thanks Mr Neo Geo for posting the fix because someone at sometime will need it! ^o)
