| tune up specs /valve clatter; tune up specs | |
| Tweet Topic Started: Feb 19 2012, 01:58 PM (993 Views) | |
| skykingjohn | Feb 19 2012, 01:58 PM Post #1 |
Hi guys my name is john and i am the proud owner of two geo metros 1 is a 1994 geo metro and the other is a 1992 geo convertible on the 1994 i have a hard start but when it gets going it is fine. motor is strong plugs look good idle is alittle low . what is a good idle speed ? on the 1992 rag top i have lifter noise and when i slow down the rpms wave 2000 /1500 about 4 times before seddling at 1000 the emissions sticker is is gone on both cars so i need timing and idle speed please . also how hard is it to change lifters . the service manual i have is a Haynes and is fair thanks john |
| Car Nut | Feb 19 2012, 02:04 PM Post #2 |
Change the oil & add some Marvel Mystery oil first, before swapping out the lifters. Mine were VERY noisy when I bought my car & cleared up a few hundred miles after doing the MM oil. |
| skykingjohn | Feb 19 2012, 05:51 PM Post #3 |
i just changed the oil but i use marvel mystery oil when i do winterizing (boat ) for fogging oil so i think i will drain out a qt and put it in place to see what happens thanks john |
| 91 ragtop | Feb 19 2012, 06:22 PM Post #4 |
The rpms should be at 850 when warmed up. Ken..... |
| Bad Bent | Feb 20 2012, 02:34 PM Post #5 |
Welcome to your new forum, skykingjohn! You'll be wanting to get a Factory Service Manual for at least one of your cars. I got mine on eBay for about $25 depending on the model. Click on http://www.ebay.com/geo+metro++service+manual The engine information will be the same in all manuals for the 1.0. My FSM has separate sections on convertible topics. High idle and searching is usually a vacuum leak of a bad/disconnected hose, bad EGR or an intake manifold-EGR-TB gasket leak. I had hard starting for a while and it was the distributor posts corroding. Fuel injector is suspect. You can test the pressure at the TB/hose connection with a gauge if you want. Always a good idea to do a compression check to see what the compression numbers are as it might be a bad valve and low compression. http://geometroforum.com/topic/2574993/1/ |
3:35 AM Jul 11
