| Need help bad!! PLEASE | |
| Tweet Topic Started: Feb 21 2012, 01:23 PM (816 Views) | |
| GeoToxic102 | Feb 21 2012, 01:23 PM Post #1 |
Ok guys so last night I uninstalled my valve cover, took out spark plugs and wires and etc because i wanted to paint my valve cover, I reassembled it all that night and the next day when I tried to start it, it will barely start!! without gas it will stall within millaseconds and then if i give it gas at most it will go to 4k rpm, I labeled all the wires so i wouldn't mix them up, im not sure whats wrong timing or something, please help im new to fuel injection and having a car with a ECU!! |
| Stiffchezze | Feb 21 2012, 02:21 PM Post #2 |
Sir Metrologist
It sounds like a vaccum leak. Check all of you vaccum lines, I bet one or more is either not connected, or broken off from age. It only cost about $10 and about 30 min to change all of them.
| GeoToxic102 | Feb 21 2012, 02:34 PM Post #3 |
I just took off one of my spark plugs and noticed it was very loose, the guy i bought the car off of, never did a tune up period... I think it is time for a tune up. |
| LukeJ88 | Feb 21 2012, 02:39 PM Post #4 |
Take heed in stiffcheeze's post. This is a very cheap way to possibly fix a lot of problems. edit:speeiling Edited by LukeJ88, Feb 21 2012, 02:39 PM.
| GeoToxic102 | Feb 21 2012, 02:54 PM Post #5 |
After testing spark plug wires, Number 2# is not even working.... they need replaced i got it to idle |
| arollinstone | Feb 21 2012, 02:57 PM Post #6 |
On a Mission from God
Don't panic It's probably your PCV valve or you just did'nt connect the hose |
| GeoToxic102 | Feb 21 2012, 03:41 PM Post #7 |
It is not PCV Valve the engine needs a good tuneup. |
| Vaultgirl | Feb 21 2012, 07:34 PM Post #8 |
Check your distributor cap for any cracks even small ones can cause big problems...trust me I know
| Old Man | Feb 21 2012, 07:42 PM Post #9 |
Why did you not get the plugs back in tight? Check to see for sure if your plug wires are on right...... standing at the drivers front fender looking at the distributer==top left is #1.....bottom left is #3....... right side is #2-----BTW #1 cylinder is the one closest to the passenger fender. |
| Bad Bent | Feb 21 2012, 09:44 PM Post #10 |
You got it to idle I had a heck of a time following the firing order diagram in the Chilton manual because it is wrong.
| GeoToxic102 | Feb 21 2012, 10:43 PM Post #11 |
Well all is good guys thanks for the quick rush help, I just order all brand new ignition parts because i was informed these have been used for the life of the engine..... installing new valve cover gasket aswell, Thanks for the help!! P.S I have two Chilton books on it. |
| Bad Bent | Feb 21 2012, 11:04 PM Post #12 |
Might want to go with the 1995 Factory Service Manual. I see one on eBay at auction for $10 and $8 to ship. Since you have a Chilton you could do with the "Preliminary" 1995 FSM for less $$$. Search for 1995 Geo Metro Service Manual I did well with the Chilton but the FSM is SOOOO much better.
3:33 AM Jul 11
