Where does this hose go?
Topic Started: Feb 23 2012, 12:07 PM (1,006 Views)
SoloCon
So, my 93 Geo metro motor 1.0L is running rich, real rich. I am trying to figure out were all these hoses go. This is going to be for off road use and have removed my EGR and anything related to emissions (I hope). Anyhow, I need help figuring out what to do with these hoses. If it is best to just cap them, please LMK. Any help would be greatly appreciated.
SoloCon
anyone? if needed, you can right click (windows) and view image to see a larger image.
Edited by SoloCon, Feb 23 2012, 03:01 PM.
A - looks to be for the IAC which has been removed. Keep it capped.
J - on my 91 is capped. But the two behind it run to my vacuum distributor.
Are you running a MAP sensor? If not, that's the rich fuel problem.
I think if you're running "blank", the only vacuum line should be for the MAP sensor. All others could be capped. Make sense?
Just shooting from the hip here.
A 93 FSM would be a valuable resource at this point for you.
Edited by snowfish, Feb 23 2012, 05:40 PM.
sphenicie
Jittney has volumes of wonderful info posted in the 'Repair Manuals- Diagrams' area. I was able to identify all of my hose questions. one stop shopping- thanks Jittney!
Edited by sphenicie, Feb 23 2012, 03:56 PM.
check for diagrams- http://geometroforum.com/topic/4018813/
