It wants to DIE :(
Topic Started: Feb 26 2012, 03:59 AM (498 Views)
SoloCon
So, I am in the process of putting a 93 1.0 Geo metro into my buggy but am having an issue with it. When "flooring" the gas, the motor won't rev up and acts like it about to die and loses power in the motor (wont Rev). At this point, if I let go of the gas and push it in very slow, I can stop if from dieing and drive. I can't even pass about 3K RPM.
As I am putting this in a little buggy, I have removed all vacuum hoses but the one going to my MAP. The TPS and MAP both show within the correct power/ground voltage.
Anyone have any other idea on what to check?
SoloCon
In the below picture, I have connected C (Map) to E. I have also fixed my 2 water (Heater lines??) as well. Besides that, everything else is just capped off.
My fuel is at about 10-14 PSI Even when reving.
Sounds like the valve timing is off, or you've got no ignition advance.
ascensions
Je conduis une petite voiture.
When I read the title, I thought it said "I wants to die.", but I couldn't believe anyone was that attached to a Metro.
