High idle 1991 geo metro xfi
Topic Started: Feb 27 2012, 11:00 PM (1,589 Views)
vikasintl
Any one experienced high idle in 1991 Geo metro xfi...
I know there are many topics for high idle but am if someone has xfi specific experience that will save my time..
Where do I start with ?
or what should I focus on?
I already checked for
vacuum leaks...
vikasintl
don't worry fixed it
poorman1
And it was?
geo pet
" my strange addiction "
do tell ? as it may help others
vikasintl
well it was bad fuel filter...but can not tell for sure it was the cause for high idle..as I have replaced spark plugs+wires+rotor+cap and cleaned egr and replaced pcv valve.....I also have removed each sensors and cleaned them...so can't say what solved high idle?
GeoStalker
Did you ever remove the TBI? Sometimes the seal underneath it sucks in a bunch of air and kicks up the idle. Placing it back on perhaps sealed it tighter than it was before.
vikasintl
no I did not remove tbi...I was wrong before..idle is still high...
Edited by vikasintl, Apr 8 2012, 12:15 AM.
mrchance
Blucifer's owner - Brad
I pulled a metro tach cluster at the yard. I'll sell it to ya, or get your own. The resolution is not super fine, but get's the job done... gives me something to do while waiting to reach speed. lol
Hogleg
Midnight Toker
Having same issue here. Idle around 12-1300. About to do some work on it.
redpepe
hi v,
mine's not an xfi but i've been struggling with a high idle for more than a month. many of those items you have checked or replaced could have contributed to the high idle. you also might check the throttle switch / throttle position sensor. small increments out of adjustment can change the idle.
mine has slowed down .... beginning, maybe 1500rpm that would not decrease below 1100 rpm is now corrected to dropping to a brief 'hunting' mode up to 1300rpm for a couple of cycles and then dropping to specs at about 800 rpm. the hunting period is what i'm now trying to fix. i think i must still have a vacuum leak. additionally and curiously, i cannot get the problem to occur unless i drive the car .... it will not happen when simply bringing the engine up to operating temps at the shop.
also i just realized that i have what appears to be a 'vacuum delay valve' in line to the map sensor. i do not recall ever seeing one in the diagrams or in photos here. do any of you have a valve in line? i never even thought about this in 360k miles ... has always been there. maybe i should start another thread to find out about this.
