runs like crap; engine troubleshooting help
Topic Started: Feb 28 2012, 12:37 PM (509 Views)
sportscar
I have rebuilt the entire engine in a 92 geo metro 1.0. after 20k miles I am having problems with poor acceleration, very poor fuel economy, loss of power, and hard starting. I have reset the only known code( map sensor) It then ran great for about 30 minutes, then back to the previous problems.;; filters, fuel pump,press regulator, coil, plugs, wires, cap rotor, distributor,vac hoses, pcv, and alot of other stuff has all been replaced, the check engine light never comes on, except when i do a pcm reset, and run the diagnostic, then the only code i get is 12.. compression is 165 to 170. any suggestions would be greatly appreciated, thank you, kevin
check fuel pressure (new does not mean correct). look to see if injector is spraying correctly
I'm sure others will post more items to check
Welcome aboard! Did you clean and reconnect the grounds on the back of the intake manifold? I also suggest you pull the timing cover and check to make sure all is still properly aligned there. Good Luck!
