| changed water pump but need help where something goes | |
| Topic Started: Mar 8 2012, 09:27 PM (176 Views) | |
| guitarranger11 | Mar 8 2012, 09:27 PM Post #1 |
I just changed the water pump on my 91 metro and I went to put it back together when I was screwing in the bolt that has the square cylinder looking bolt that screws down the piece that has the spring on it but my problem is there's a wire looking thing it actually looks like a paper clip that was unravelled. But where does that paper clip looking thingy go. Thanks so much everyone |
| t3ragtop | Mar 8 2012, 09:41 PM Post #2 |
Turbo3 Tweak
this is the clearest pic i could find in short order. it's a double spring. both loops go through the hole in the adjuster cam lever. both other ends go onto the extended bolt on the oil pump as shown. |
| guitarranger11 | Mar 10 2012, 05:38 AM Post #3 |
Thanks a million t3ragtop the picture and what that thing was took care of my problem. I appreciate your help. |
| nerys | Mar 10 2012, 09:11 AM Post #4 |
Grr
where did you get the AL water pump pulley ? or is that painted steel? |
| t3ragtop | Mar 10 2012, 09:49 AM Post #5 |
Turbo3 Tweak
nerys, if that question about the aluminum water pump is for me, that's an oem aisin replacement, unpainted (as it's a service part) and bolted on "out of the box." i don't paint oil pumps, either. it's easier to see leaks from both pumps if you don't pretty them up. also, the oil pump is a different story. i only use hard to find high volume oil pumps on my turbo3 builds because the oil pump has the additional load of supplying oil for the turbo. given the option, i hand select the pumps as well. |
5:17 AM May 19
