driving a convert. with bad bearings
Topic Started: Mar 10 2012, 03:21 AM (662 Views)
suntzzu
So I am headed to get my convertible on Sundays but my younger brother has it,and says rear bearings are squeaking pretty loud.he repacked the grease but that's all he can do right now.would you trust trying to drive it a few hours on a highway? I read the thread about fixing it which can do once it's home but he's a college student in an apartment with no tools :p
More info please. Which bearings are making noise?
suntzzu
Mr Murf 59
Mar 10 2012, 03:23 AM
Passenger rear
So a wheel bearing? Not sure how loud the bearing noise is. If its really bad. Fix it soon. If its just a little anoying, it could drive that way for some time.
Jack it up, grab hold and give the wheel a shake - if there is slop in the bearing then it's time to change it. If it's still tight and just squeaking it will probably hang on for a while. Warning - Your results will vary.
MR Bill
Take a few tool and extre drun with bearings and change.
Two hours is a long ride on potentially bad bearings. :O I've rode a bearing rumbling for some time. But squeaking sounds like the bearings are dry. :hmm You say your brother repacked the bearings. Not sure what that means? :news
I have a feeling that he removed the rear hub and packed the center cavity. :hmm The bearings are sealed so no grease got in there. :shake That's why it's still squeaking. :banghead
If it were me, I'd bring a bring bearings, grease, brass punch, hammer, socket set, and torque wrench. Change them out in the parking lot. :gamerz Working together, this shouldn't be that tough of a task. :cheers
MR Bill
Mar 10 2012, 09:19 AM
:thumb Two preloaded drums would be great! :thumb
t3ragtop
i had to do an emergency rear wheel bearing replacement while i was on the highway. auto zone had the bearings in stock at one of their stores in a small town and the actual repair took about 45 minutes.
planning ahead for that repair, take a big punch (i use a brass bar about 1/2" in diameter and a foot long) and a big hammer (i use a short handled 5 pound sledge) along with a jack, a tire iron, and a can of wheel bearing grease. you should also take a tool bag with a standard range of stuff in it.
it's really a pretty straight forward repair. you can buy your parts ahead of time, read up on the sequence (yes, there is a method) and get your war face on. :D
91 ragtop
And don't forget the rags and handcleaner
Ken.....
Preloaded drums = priceless :thumb
