? about stainless steel exhaust valves
Topic Started: Mar 16 2012, 06:23 PM (2,180 Views)
solerpower
If I'm switching to stainless steel valve guides on my G10 what is the truth about switching to bronze manganese valve guides, do I need to do this for longevity purposes? Any data or first hand experience to support this? Thanks
ron.wilson09
If you have a hundred thousand miles on it an it doesn't show much valve guide wear then I wouldn't worry about the guides that much.
I have used stainless steel valves and standard valves. It all depends on how you tune and maintain your car to prevent burnt exhaust valves. Correct timing, regular maint, and a little love will go a long way. I prefer the stainless because of that extra prevention on my daily driver.
3tech
You don't need to do it, but they do wear better than the stock cast iron guides. The stock guides are small for the application and are prone to wear. As far as the valve material, it has no effect on the guide choice.
I get my guides from 3Tech when they are needed.
solerpower
Thanks for the information. I went with the bronze manganese valve guides for the the exhaust matched with stainless steel exhaust valves. All from 3-Tech. Went with what ever Parts Dinosaur has for the intake valves, and there valve guides for the intake. I was already doing a order for other stuff at Parts Dinosaur, but the price difference was only $20 for the exhaust components at 3 Tech. My intake valves and seats looked fine but for $18 dollars I'll start new. The exhaust seats looked ok, but the exhaust valves were questionable.
