New Member, Just Bought My First Geo!; 1994 Metro 3 Cylinder 5-Speed
Topic Started: Mar 21 2012, 09:19 PM (964 Views)
johnjm22
Mar 22 2012, 03:28 AM
I'm pretty sure I'll need stuff for the AC/Heater, neither of which works right now, but I can see that it came from the factory with both originally.
Probably the fan that doesn't work, the switch itself is famous for failing.
56 MPG seems abnormally high. I figured out the MPG by topping off between two gas stations, so it might not be perfectly accurate.
Anything less than a full tank (500 miles or more) is too small a sample to rely on at all. There's a half gallon variance in when the pump handle cuts off, half a gallon is pretty impressive when compared to .623 gallons.
