| one way valve in brake booster line...location? | |
| Tweet Topic Started: Apr 14 2012, 03:27 PM (1,509 Views) | |
| vikasintl | Apr 14 2012, 03:27 PM Post #1 |
I would like to know the location of one way valve in there metros? this one valve is present in all the metros...ie. 91,94 and 96? 1.91 metro xfi - if valve is present in this year? if yes where is the location...is it between manifold and and firewall or between booster and firewall ? 2. same question for 94 metro- 3 cyl. 3. same question for 96 metro - 4 cyl. currently I have no valve in 91 and 96 while in 94 one way valve is between manifold and firewall (or in other words manifold and that metal pipe) |
| Rooy | Apr 14 2012, 03:37 PM Post #2 |
![]() The fitting/nipple at the booster contains the check valve. This is where it is on my '91. I think I remember reading on this site that it changed in other years. |
| vikasintl | Apr 14 2012, 04:38 PM Post #3 |
no I was asking about plastic valve not the metal one which goes directly in to booster |
| Rooy | Apr 14 2012, 08:27 PM Post #4 |
I believe the check valve is part of that fitting. There's no other check valves on my '91. |
| vikasintl | Apr 15 2012, 08:43 AM Post #5 |
are there are two check valves ...one metal one ...at the end of that hose ....which goes directly in to the booster? the other one...plastic one...which goes in the hose between metal line and manifold? |
| kirk343 | Sep 17 2012, 03:07 PM Post #6 |
There is a plastic check valve in the hose coming from your brake booster to the metal line on the firewall. Good luck....they are discontinued. |
9:30 AM Jul 11
