| 94 Geo metro rough ignition,rough idle,sputter,etc; need to figure cause(s), how to repair | |
| Tweet Topic Started: Apr 17 2012, 06:40 PM (7,711 Views) | |
| gmz760 | Apr 25 2012, 08:12 PM Post #16 |
UPDATE- replaced the coolant temp sensor, as it was found to have a nice crack through it, preventing it from making a solid connection. after replacing, the car started right up. its still running a little rough when idling, n that damn alternator belt is still being a lil b*tch, but definite progress is being made. we still have the o ring to the water pump to replace, and getting the idle back to normal after all the adjustments. then its on the oil leaks, cv boot, and all the "lil" stuff... id appreciate any feedback or advice though! |
| Bad Bent | Apr 25 2012, 09:39 PM Post #17 |
The Alt belt is as you describe. Check to see if the top adjusting bolt has sufficient room for adjustment. I got the same belt for both our cars however om the '96 the length was just long enough that the adjusting bolt was all the way back in the slot. It looked like it was tight and the belt felt tight but it squealed. A 1" shorter belt helped, and centered the bolt in the slot. Still it is a good idea to remove the belt and first scrub the pulleys with steel wool and then clean the pulleys with alcohol. That and a batorback belt is recommended. |
| gmz760 | Apr 27 2012, 05:55 PM Post #18 |
thanks for the tips...i knw i read somewhere in these forums the correct size/dimensions/stats/whatevr for the o ring tht goes to the pipe that the water pump goes to...if anyone can point me in the rright direction, id appreciate it. |
| Bad Bent | Apr 27 2012, 07:27 PM Post #19 |
1-3/32" I.D and 1/8" thick. making it 1-11/32" O.D. (1.34375 = 34.1mm) is the one I have. Some members have taken theirs down to a hardware store for a sizing and added some Black RTV to the seal to get it to fit. There is one for sale at http://www.gmpartsgiant.com/Page_Product/PartDetail.aspx?modelYear=1989&model=Metro&make=Chevrolet&catalogCode=15M&majorIndexID=01&isBigPicture=False&minorIndexID=SU0101601 |
7:47 PM Jul 10
