| Engine Swap; Putting a 96 3cyl 5sp engine in a 95 What problems might I have with OB2 computer? | |
| Tweet Topic Started: Apr 18 2012, 08:08 AM (705 Views) | |
| mollymutt | Apr 18 2012, 08:08 AM Post #1 |
I have a 96 metro with a lot of rust but a good runner. I also have a 95 with a much better body but the engine was a little toasted because of running with no water. They are both 3cyl 5speed but the 95 is LSI with AC and the 96 no AC . I would like to put the engine and trans from the 96 in the 95 and I was wondering if I would have problems with any difference because of the 96 has the ob2 computer set up for checking emissions? |
| Deleted User | Apr 18 2012, 08:15 AM Post #2 |
Hello, mollymutt! All you have to do is just put it in. (Beware when I say "just" )The '95 parts that you want to keep with the engine are: 1. The complete intake manifold and all associatied parts. 2. The distributor. 3. The thermostat housing. 4. The timing belt, timing idler, and timing gears. 5. The timing cover. There is no need to change the oil pump. Remove the crankshaft sensor. Have a nice day!
| Woodie | Apr 19 2012, 04:04 AM Post #3 |
No need for 4 and 5 on Geo Glenn's list, just leave the intake, distributor, and thermostat housing with the car, and ignore the crankshaft sensor. |
| Deleted User | Apr 19 2012, 11:17 AM Post #4 |
Agreed. I am a purist. Although, the next guy who looks at what you have done will shake his head. |
| shaunhlavaty | Apr 19 2012, 01:28 PM Post #5 |
ok guys quik question...i recently purchased a 94 3/5 metro and my goals for it is to put a 1.3twin cam GTI motor in it...so i guess what im askin is are the 1.3Single cam and 1.3 twin cam the same block? like can i take the twin cam head and bolt it to the single cam block? because i cant find an actual GTI motor to save my life lol but the metro 1.3s are everywhere and found GTI heads online Edited by shaunhlavaty, Apr 19 2012, 01:32 PM.
| Coche Blanco | Apr 19 2012, 01:33 PM Post #6 |
I'm pretty sure they're the same, but I don't think the bottom ends are the same. |
| clarkdw | Apr 19 2012, 02:54 PM Post #7 |
pm sent |
| Woodie | Apr 20 2012, 05:10 AM Post #8 |
Block is the same but the pistons and connecting rods are not. |
7:48 PM Jul 10
