Polishing the Crankshaft
Topic Started: Apr 18 2012, 06:45 PM (2,452 Views)
catfishWhisperer
Apr 19 2012, 11:12 PM
Geo Glenn
Apr 19 2012, 11:06 PM
Thanks for clarifying that.
Do you have one of these?
No, the only micrometers that I found at Harbor Freight all had the blunt tip.
OK.
What's the ID of the large end of the rods 1, 2, & 3 without the bearings installed.
We'll reverse figure this one out . . .
catfishWhisperer
I'll measure that tomorrow and report back.
catfishWhisperer
ID of the big end of the connecting rods without bearings installed all measure 1.772". This measurement was the same for all three rods.
catfishWhisperer
Apr 20 2012, 06:13 PM
Your nominal rod bearing thickness on #1 is 0.0580"
Your nominal rod bearing thickness on #2 and #3 is 0.05825"
If you would install rod bearings with a thickness of 0.0585" in all 3 rods, theoretically, your piston to crankshaft clearance will be 0.0015".
I just happen to have a such set of rod bearings.
catfishWhisperer
Geo Glenn, I'm interested. Just sent you a pm.
catfishWhisperer
Apr 20 2012, 09:40 PM
Got you covered, CFW.
catfishWhisperer
Thanks for the help everybody.
