check engine code; no code
Topic Started: Apr 20 2012, 01:10 PM (541 Views)
coyote93
I have a 93 Metro, California spec, 5 speed. The check engine light is on and the code flashes 5 times then 1. My list of codes in the Clymers repair manual does not list this code. The highest number of flashes for any code listed is 4 plus whatever. The book lists this code "5 flashes then 1 for older Sprints indicating ECM malfunction. This is not to be confused with code 51 for the Metro which is listed as 4 flashes then 1 and refers to the EGR system.
Does anyone have information that would help? The car runs fine except for high idle, 1500rpm.
Muchas Gracious Amigos,
Coyote93 :rocker
http://geometroforum.com/topic/638390/
51 is EGR. Probably clogged passages through the intake manifold.
