blinking code 46
Topic Started: Apr 21 2012, 02:43 PM (858 Views)
mrchance
Blucifer's owner - Brad
so, I got that 23 is Man Air Temp sensor, and 51 is EGR (what's new? system spotless, new vac lines. always done it. maybe zip tie lines for better seal?).
what is 46? I have checked it multiple times, every time I count 4 then 6. lol. (it flashes every code 3 times)
thanks for your help!
-Brad
mrchance
P.S. I'm running ChevTech in the tank at appx 1/2 bottle to 1 full tank. appx 1oz/1gal (IIRC, it was a 16oz bottle). runs decent, smokes a wee bit at high revs (5500-6000) in 1st, 2nd. Then clean(it clears the carbon in the cat i assume)
EDIT: found this. ---> http://geometroforum.com/topic/4739275/1/ I'll follow this and see if it helps.
Edited by mrchance, Apr 21 2012, 02:56 PM.
poorman1
46 = Idle speed control motor circuit?
econoboxer
I am the one on the left.
yep. I have it too. Let me know if you figure it out, since I have put it on the back burner.
mrchance
it was fine till I messed with the TPS and Idle. I'll set that, and see what happens. Blucifer is a 94... the one in my profile.
GeoPete
AAS Auto Technology past ASE Master Tech
In the same vein, has anyone had this with the check engine light? No code is set, but the light flickers very fast and faint once in a while.
That sounds like a short, loose or broken wire or bad ground. Try moving the wiring harness around a little when it happens. :hmm
