| Oil in the Air Filter Housing | |
| Tweet Topic Started: Apr 21 2012, 10:02 PM (940 Views) | |
| Geeeo | Apr 21 2012, 10:02 PM Post #1 |
Geeeo
On my 1.3 I have a little OIL in the line from the PCV. The car burns NO oil at all and runs perfectly maybe the PCV is bad? I am going to get an AC Delco one from Chevy next week and see if it helps. Does anyone have any input? |
| Shinrin | Apr 21 2012, 11:41 PM Post #2 |
The pcv clogs and is often neglected. If in any doubt replace it. While your at it pull off the Ytube and clean it out as well. Gunk builds up in it as well as the pcv. When one clogs the other is probably clogged. Even if it's not clogged, you don't want to put a new pcv in only to blow a bunch of gunk into it that's stuck in the ytube. |
| tirebiter | Apr 21 2012, 11:47 PM Post #3 |
Burns no oil as in you never add any between changes or you never see any smoke from the exhaust ? |
| GeoPete | Apr 22 2012, 12:24 PM Post #4 |
AAS Auto Technology past ASE Master Tech
Put a catch can on it. |
| Shinrin | Apr 22 2012, 07:34 PM Post #5 |
Catch can will solve it, but it's a band aid on a bullet wound. The pcv and Ytube are you easier and most likely problems. |
| tirebiter | Apr 23 2012, 07:04 AM Post #6 |
My guess would be bad valve seals ! |
7:48 PM Jul 10
