I messed up my fuel injector
Topic Started: Apr 22 2012, 10:30 AM (1,808 Views)
geo-miami
Yestarday, I had a brillant idea to clean the injector of my car ( I follow good post of method of removing a fuel injector by Geo Glenn ) spraying with Berryman B 12 chemtool to improve perfomance and I messed it up. :shit
I put them back and started the car, it did not sound ok. I took the car for a ride,but the sound no change.I turn it off and did not start again,died.
I made a mistake not reading feedbacks about injectors from this forum where always found best post. Last nigth I did it, too late. so what do you think about it. :smackface
Redo it and check to make sure the wires are not bare and shorting against the TB. Check the injector for any clogging. :hmm
geo-miami
wires ok, but how to unclogged if it is ?? what kind of product may I use to avoid any malfuntion
I checked and this link: Fuel Injector Cleaning is by blue rhino, another method?
These guys will do it for $21 + shipping and down time. http://www.witchhunter.com/injectorserv1.php4
geo-miami
Finally I could fix my fuel injector, I was reading post about it ok I am going to the point.
I went to junk yard get one fuel inject, reinstall in my car took off gas return hose until some gas when out reconnect again that's it
I checked link to clean injector,good site, I will know where to go in WA state to do that job. I am traveling there next month.
thanks all for your help. :drivin
:congrats
The best and easiest way to clean a fuel injector is to put 10 ounces of Chevron Techron in the fuel tank with a full tank of fuel.
http://geometroforum.com/topic/4551987/
Geo Glenn
Apr 23 2012, 11:13 PM
You think 1 treatment is enough?
Apr 23 2012, 11:21 PM
Geo Glenn
About 100 miles later, you're good to go.
Of course, I use the stuff all the time. Gonna take a look at some G13 intake valves here one of these days . . .
geo-miami
Geo Glenn
I did that, a Pet Boys attendant recommend to use GUMOUT concentrated, next time I will try with chevron tech anyway thanks for you advise
geo-miami
Apr 24 2012, 10:58 PM
Geo Glenn
These are both good.
mwebb
FOG
you guys are learning
really
used to be you all thought that other cleaner was good stuff
sea-Hoax, same as coleman lantern fuel
it is not a good fuel system cleaner , it does make smoke , making smoke is not the bar by which fuel injection system cleaning is measured .
Chevron Techron is the way to go
or
BG44k when the Chevron Techron is un available ... they are the same thing
only BG44k is 2x more expensive.
Jittney
mwebb
Apr 24 2012, 11:13 PM
really
Priceless :)
reddevillhs17
mwebb
or
I was going to ask about 44K, good to know there is something comparable for a cheaper price, thanks.
