Checking the ECM; Doesn't seem to be working
Topic Started: Apr 22 2012, 02:33 PM (518 Views)
terryaward
Timed the engine with the paper clip in the bypass block, 8 degrees as directed. Pulled out the paper clip, timing light shows 8 degrees and not 16-20 degrees as expected. Is the ECM working? Would the car start without it working? Is there a fuse that may have blown out causing the ECM not to work, but still allow the engine to fire up? :hmm
mwebb
FOG
with the timing light connected ....
look at the timing mark
goose the throttle , timing should advance upwards of 40 degrees depending on rpm reached
if yes
the ECM does function and is capable of controlling ignition timing
if the CEL comes on key on engine off
and
you have 5 volts reference at the MAP sensor
the ECM is functioning somewhat anyway .
having said that
if the closed throttle switch does not close
the system may not go into base ignition timing
iBLKBRY
At low idle, eight degrees with the jumper removed is normal. A scan tool would show the movement more accurately.
