Bought new geo and almost blew it up
Topic Started: Apr 22 2012, 11:57 PM (600 Views)
chris70cuda
I purchased a 97 geo metro sedan 1.3 auto with air off of ebay two days ago. Well I flew to Philly, Pa to pick the car up. Guy on ebay said it was rust free and runs great. Well when I get there there are a few problems. First a small nickle size hole in passenger side front frame and rust buble near narrow strip of rear quarter panel. The steering is really hard to turn. I just sold my 97 3/5 and the steering was much easier. The driver side window does not align properly because one corner is off by 1/4 inche and is allowing the air to come in good. The grand finale is: Oil was completely fun when I left 16hrs ago and now there is no oil in the pan. The light started blinking when I hit the brakes. So I checked the dipstick and no oil on it. I look under the car and the hole underneath on passenger side is soaked in oil. I am guessing the crank seal is bad. I replaced one on my 97 3/6 1.0 but never on the 1.3 engine. Is it the same. Can anyone give me some quick and easy instructions/tips.
But I did get 38mpg and all three fillups. Probably because barely any oild in engine...less friction. hahah.. Why me?
It's exactly the same, except there's much less room to maneuver around in there, belt pulley is about 1/8th of an inch from the frame. You'll need to remove the motor mount and lower the engine a bit in order to get the pulleys off.
chris70cuda
Thanks for the info. I was not sure what I had to take loose to get the pulley down far enough to take off. Do you think a jack with a piece of 2x4 on it underneath the oil pan will be enough to support the engine as I lower it and raise it back up when I get done?
chris70cuda
Apr 23 2012, 01:05 PM
yes lowering it with the floor jack and a 2x4 would be enough to support the engine. Just dont lower it too much, just enough to get the pully off.
