95 geo 1.0 wont start; 1.0 wont start/rebuild head
Topic Started: Apr 23 2012, 06:17 PM (913 Views)
hillvalleygeo
just recently had my head off and had it prof. redone with new valves..this is my second time having the end off..replaced head gasket on the first trip...put it all back together this time with alll new gaskets..and now i cannot get it to start...went over the timing over and and checking everything...getting fire and fuel...double checked everything i could think of and cannot come up with a conclusion..alll grounds and vaccums are hooked up...thanks for any help
paul11211
Did you check to see if it was sparking? that is probally your problem, myabe your coil is bad?
Does the engine turn over? It just doesn't start.
Please try to be a little more specific with your descriptions of your no start issue. That will help us better diagnose where the problem might lie.
hillvalleygeo
engine turns over just fine...plenty of spark...thanks
:hmm Time to check the compression. We had one member who had the lifters assembled improperly.
I'm sure you know about the oil check valve in the head but there is also the oil relief valve in the oil pump that would clog.
Spark at the plugs so the rotor wasn't left out of the distributor. :smackface
hillvalleygeo
ok..pulled head back off to double check everything..is there an oil check valve in the head or is it just the one on the lower left hand corner of the block? Also...is there something on the head gasket that needs trimmed for oil passages..there seemed to be excess oil when i tore it apart..plenty of oil in the on the top end tho...thanks
95-3banger
The oil check is in the corner of the block, not the head. That wouldn't make it not start anyway. Did it sound normal on the starter? The injector is firing?
common problem is that the lifters are not working properly. do a compression check to see if the valves are closing OK. post your compression #s
hillvalleygeo
thanks for the help...putting back together again tonite and will post compression numbers..whats the normal for these cars thanks
Airsmithy
I just had a problem with my car not starting after doing some work. I replaced the distributor. Kept the wires on the old distributor to swap wires correctly, and I still screwed it up. Found the firing order chart, redid the wires, and it fired right up. You may want to double check your plug wire order. I found this post most helpful.
http://geometroforum.com/single/?p=632220&t=4751395
