Quick timing belt ?
Topic Started: Apr 24 2012, 04:49 PM (611 Views)
chris70cuda
I need to replace the crankseal on my 1.3 so I thought I would just change the timing belt as well. The car has 92,000 original miles on it. If I mess up the timing by a few teeth will it destory my engine/valves. I did one on my 1.0 and never had the problem or worry. Is this the same for the 1.3 engine?
Non-Interference
chris70cuda
Great, that means I dont have to worry. Is setting the timing the same? What would you recommend for timming.
On the way to the auto parts store to buy some parts.
Exactly the same as the three cylinder, just harder to do because there is much less room.
