| findind a throttle body; 1994 geo metro throttle body auto. trans. | |
| Tweet Topic Started: Apr 29 2012, 04:48 PM (702 Views) | |
| motown1 | Apr 29 2012, 04:48 PM Post #1 |
Does anybody know someone or have an e-mail address or phone number I can call to get some info on the throttle body I have and how I can find it. I am new on this board and at this time not real familiar how to navigate around and find what I am looking for. |
| clarkdw | Apr 29 2012, 06:05 PM Post #2 |
Take off your air filter so you can see the top of the Throttle body. If you have four bolt heads in a square pattern visible and you have a rectangular black box bolted to the rear of the throttle body then you have "upgraded emissions" throttle body and you can use one from a 94 or 95 at least. (possibly newer but I am not positive) If you have two bolt heads visible on top and at the rear of the throttle body two shorter studs with nuts then you have the earlier emissions throttle body and you can use one from an earlier year. What is the problem with the throttle body? If it is the later "upgraded emissions" there is absolutely nothing inside other than the injector and the fuel pressure regulator to create issues. Either can be dealt with without changing the throttle body itself. |
7:47 PM Jul 10
