| Swap, what am I looking at | |
| Tweet Topic Started: May 1 2012, 07:36 PM (559 Views) | |
| angus6 | May 1 2012, 07:36 PM Post #1 |
Got a 95 4cyl and auto have a line on a rusted out 96 with 3cyl 5spd, any heads up on the swap ? |
| Shinrin | May 1 2012, 09:00 PM Post #2 |
Swapping what? Motor and trans, just the trans, wheels? Need to be more specific. If you do an engine swap, swap everything with it. Intake, dist, everything. The engine bays are the same, so everything will go in no problem. |
| angus6 | May 1 2012, 09:25 PM Post #3 |
the 3/5 into the 95, same ECM's ? |
| mjspiess | May 1 2012, 10:36 PM Post #4 |
The ECMs won't be the same. The '96 has more sensors and it's OBDII. Having the whole donor car would extremely help. Here is a tutorial on auto to manual swap to give you an idea of what you're up against: http://www.teamswift.net/viewtopic.php?f=9&t=52368&hilit=automatic+to+manual |
| Good bye | May 1 2012, 11:04 PM Post #5 |
A complete donor car is the key to success. You probably will have to drill a hole for the tranny mount and the clutch cable. All the rest should bolt in. It will take a lot of time there is a lot to change. I went from a 4/5 to a 3/5 in a 95 sedan with a complete donor car. |
| Deleted User | May 2 2012, 12:12 AM Post #6 |
It's major surgery, but it has been done. |
| angus6 | May 2 2012, 08:37 AM Post #7 |
So there's a bit more the the days of pulling the 6 banger and powerglide and dropping a small block and 4spd in it's place, thanks for the link mjspiess . Geo Glenn I see your just a bit south of me , I'm up in Hannibal . Go to look at donor this evening |
7:46 PM Jul 10
