| questions about my rebuild process? | |
| Tweet Topic Started: May 1 2012, 09:59 PM (539 Views) | |
| paul11211 | May 1 2012, 09:59 PM Post #1 |
Like I posted earlier I just finished my rebuild, and something is wrong with my oil pressure? I I ran my engine for a couple of minutes would that hurt anything? I put a lot of oil in the cylinder and stuff and used white grease on the bearings and everything? I just want to make sure it did not hurt anything on the new engine. thanks for all your guys help. |
| catfishWhisperer | May 2 2012, 11:32 AM Post #2 |
I'm new to these metro engines, but hope you figure it out. |
| Spock | May 2 2012, 12:15 PM Post #3 |
Live Long and Prosper.
What is wrong with your oil pressure? |
| snowfish | May 2 2012, 12:37 PM Post #4 |
Only real way to see oil pressure is to put a gauge on it. Pull the plugs, hook up your gauge, and spin it for a bit. Then you'll see if there's oil pumping or not. You'll probably be fine. As long as it wasn't rattling & knocking. Good practice, for builds, is to spin them until the light goes out, or you read pressure on the gauge. Then you're OK to test fire. |
7:46 PM Jul 10
