01 Automatic metro stalling out
Topic Started: May 4 2012, 09:41 PM (847 Views)
redparrott727
Hi, I have an 01 automatic 4cyl metro that keeps stalling out, and sometimes has trouble shifting, It has the following trouble codes
p0455
p0420
p0340
p0132
p0756
p0123
Any suggestions?
mwebb
FOG
working from memory
the p0340 is related to ckp or cmp or correlation of ckp cmp
it is the most likely cause of the problem
verify that the timing belt is aligned correctly
check intake vacuum , if it is not 20" at hot idle , it is likely cam timing is incorrect
also
i do not know if the automatic metros have lock up torque converters ... but if yours does
disconnect it
and see if the stalling diminishes or goes away
You've got a bad ground. No way you have six different sensors malfunctioning. Main sensor and computer ground is on the cam position sensor housing, driver's side top of the engine, the point closest to the battery.
redparrott727
I know at least the o2 and emmssions are true because they have been there forever and won't go away, does anyone know any tricks to keep the engine light off because of those 2?
For the p0420 you need to replace the cat or downstream o2 sensor.
