cam sensor
Topic Started: May 5 2012, 05:04 PM (713 Views)
slayu2day
Where is the cam sensor located on a 2000 metro 4 cyl.
Yikes, I dont think it came with one. But I could be very wrong. It did come with a crank sensor with a sprocket the the crank sensor reads. Man, I just looked at my 99 head and I didn't see anything resembling a cam sensor.
Unless its in the dizzy.
From Jittney's Diagrams: Diagrams 98-01
Part #5: POLE PIECE DISTR PICK UP,(DIST GEN SIGNAL),(02.383)
Shown also at the bottom on the wiring diagram: https://docs.google.com/file/d/0ByE-eQuO2HRpMTdkMGVkMzUtODczMS00MDNiLWEwMGQtZTYxOGRlNWUxMTdl/edit?pli=1
slayu2day
I know it has one, cuz' the parts store had to sensor in stock. I flashed the code and thats what it said was bad.
All Metros have a cam sensor, the three cylinders are inside the distributor, the four cylinders have a little housing in place of the distributor that does nothing but hold the CPS.
That being said, they very rarely go bad, I think it more likely that you have a wiring problem or a broken timing belt.
