| COMPRESSION READING ON MY NEW REBUILD | |
| Tweet Topic Started: May 6 2012, 09:27 PM (541 Views) | |
| rydholm11211 | May 6 2012, 09:27 PM Post #1 |
Big sky
I just did a compression reading on number 1 and 2 cylinder after I did A complete rebuild top and bottom, bored it .020 over new pistons and everything, and so far I have put on about 80 miles and both readings on the cylinders is about 110 psi? is this common for a rebuild? Thanks. |
| Coche Blanco | May 6 2012, 09:28 PM Post #2 |
Yep. Wait a few thousand. Close to 10. |
| dayle1960 | May 6 2012, 09:30 PM Post #3 |
Did you test like JM suggests? http://geometroforum.com/topic/2574993/ Might want to look at this link and maybe your numbers will come up a bit. Hope this helps. |
| Shinrin | May 6 2012, 09:53 PM Post #4 |
Numbers do come up as it breaks in. Mine sits at about 210 about 10k miles after a rebuild. A lot of people get around 140 right after the rebuild. |
| rydholm11211 | May 6 2012, 10:03 PM Post #5 |
Big sky
Im going to left in all the spark plugs but the one I was testing and I did not leave the throttle wide open, That is probaally my problem, I will have to retest the right way. |
7:46 PM Jul 10
