| KP head gasket | |
| Tweet Topic Started: May 16 2012, 09:46 AM (2,237 Views) | |
| lelio | Feb 10 2013, 01:04 PM Post #16 |
Lelio
like i said i used the no blow in the rebuild i was curious about this gasket tho , the set i used the parts said made in japan and looked oem or atleast close i suppose . I will prolly use this gasket on my auto car later on .
Edited by lelio, Feb 10 2013, 01:06 PM.
| HelterSkelter | Feb 12 2013, 03:10 AM Post #17 |
#1 Pizza Driver
i'm gonna go check out the napa kp gasket when i wake up later. if it looks good i will be buying it and maybe putting it on wednesday and i'll let you guys know how it turns out. i have coolant disappearing and it's not leaking so i think it's going into the chambers. |
| z34-5speed | Feb 12 2013, 04:43 AM Post #18 |
Formerly "Tech Certified"
+1 for the "no blow" gasket. Do not touch the oil holes. Mark can explain to you in detail why not to if you call him. He's a super nice guy and extremely helpful! |
| Deleted User | Feb 12 2013, 01:06 PM Post #19 |
Any head gasket installation will be more likely to seal against freshly machined surfaces. Heads and blocks get machined on all of my engines. |
| HelterSkelter | Feb 12 2013, 07:39 PM Post #20 |
#1 Pizza Driver
kp head gasket is in. also i figured out an easy way to put the timing belt back on, but it's a secret :evillol. time will tell how well it works. it looks just like the beck arnley one and the no blow ebay one though, i'm pretty sure they're all basically the same. |
2:28 PM Jul 11
