removal of heater core; jesus christ
Topic Started: May 22 2012, 08:59 PM (4,629 Views)
fusion505
Ok, so when I did this at the U-pull-it, I guess the gas pedal had already been removed. Anyway...
I've removed my dash and now I'm looking at this shit. The chilton gives no useful advice. Why is this thing still connected?
It looks like I have to remove the gas pedal to remove the heater core. But I have to remove the heater core to remove the gas pedal! WTF!!!
fusion505
upon further fanagling, I think I can sneak past the gas pedal, but the air conditioning box on the right is in the way...
and I REALLY don't want to deconstruct my air conditioning system to do this...
Edited by fusion505, May 22 2012, 09:20 PM.
fusion505
I think I'm ready to set this goddamn thing on fire
Relax, please, I pulled the heater out the passenger side of the '96 with the dash pulled 6" out.
If the gas pedal is to be removed then it is held on with one nut and pulls out toward the heater box.
Honestly I don't remember but it does pivot on the bar that goes through the bracket.
Nyquil-Junkie
I think I'd rather be cold that change a heater core.
It's a nightmare in any car.
MR Bill
You are just making it hard on yourself by fighting it. It will all come out on the
passenger side. Do a search on heater cord removal on this web site, you should
find the answers you need. I will look and scc what I can find for U also.
I'm laughing, but then again, not. Been there, done that. Twice. Not fun at all.
While you're in there, replace the foam on the duct work, and clean out all the debris from the AC housing. It's time well spent.
Chilton's manuals are good emergency butt wipe material, at best. IMO.
Get a Factory Service Manual for your year on eBay.
TimmyD
A Metro Driver
On the vert, I had to remove the whole dang thing 'cause meeces had a home in the ducts at one time.
I got a new heater core that I'm going to install so that I don't have to tackle it again for a while.
Edited by TimmyD, May 23 2012, 05:58 PM.
Fusion 505, you really need to become a comedian. I got a big chuckle reading your posts. Listen to the advise and so a search on GMF. It's a lot easier than you think it might be.
Good luck and let us know how it turns out.
downsouth
Shade Tree Mechanic
I just replaced mine recently! To get it out I cut that ear off that is behind the gas pedal with my Sawzall. Then after I bolted the box back on I glued the ear on. Worked for me!
downsouth
Jun 8 2012, 10:14 PM
I see why it says shade tree! :whistle
94RHDRollerskate
Forum Stud Muffin
Please explain the separate A/C box? I'm getting ready to order a heater box/blower assy from a guy in Australia. My car is an A/C car, and I think I only have the under hood components. Under dash components are non-existent. Want to make sure I have everything to complete both systems.
JoeBob
Why you Mutt!
Nyquil-Junkie
May 22 2012, 11:32 PM
I know of two cars that it's easy money to change the heater core:
1962 Rambler American (mine didn't come with a heater, I installed one from a junkyard in an hour or two)
1979 Chevette (right there on the firewall...remove the cover and it's right there in your face!)
Lincolns...they start with the heater core and build the entire car around it. When the heater core died, I just bypassed it and froze my ass off!
Are Metros the same? I hope to never find out!
Rollerskate, the ac box is the middle box of three in an ac model. If yours is not equipped with ac, then you will have just a round duct where the ac box goes. To add ac, you would remove the round duct and bolt up the ac box in its place. Inside the box (looks kinda like the heater core box) there is an evaporator, and it has two lines that go out your firewall, just like your heater core. Let me know if you have any other questions on this.
geo-miami
Nov 18 2012, 04:05 AM
I got a question, I need to change my heater core, got A/C, do I have to disconnect my A/C first or is there any other way to do it?
