Really fast tire wear; Tire wear
Topic Started: Jun 7 2012, 12:50 PM (391 Views)
Bchev
I bought a 2000 metro about two weeks ago and put new tires on it. In the last 500 miles both front tires have worn down a LOT. Front right to about 20% tread and front left to about 50%. Everything seams tight under there. Tie rods, ball joints, axles. I'm not sure what it could be. Maybe bearings? It looks like either the car is moving faster then the tires or the tires are moving faster then the car. Any ideas would help a lot
Thanks
First off, Welcome to the Party! :cheers
Second, did you have an alignment done, when you got the new tires? :news
Bearings will cause wear too. ^o) But you can hear them "growling" giving you a clue that they're getting ready to go. :oshit
Or you may have frame horns that are either bent or rusting through throwing the front end out of whack. :banghead
Edited by snowfish, Jun 7 2012, 02:14 PM.
BigRobRN
4 wheel alignment at a specialty shop that only does alignments. Unless you went with a really crappy tire
HelterSkelter
#1 Pizza Driver
Bchev
Thanks
:ermm: the car and the tires move at the same speed, i'm not sure what you mean o.O.
go to an alignment shop and see what your toe in is. i bet it's all screwed up like both tires way negative or way positive.
Jittney
Welcome to the forum, Bchev :coffee
Has the car been in an accident?
hobsickle
HS Science teacher
Here's a good hint that the toe is off (in or out): when you hit bumps (or wet patches) the car briefly pulls to one direction or the other (or one direction, then the other). It is also possible to get a crude measurement of the toe with a tape measure, comparing the spread of the tires on their front side and the spread of the tires on their back side. (You can even adjust the tie rods to get a better--but by no means perfect--toe adjustment using the tape measure.)
Jittney
A friend had what Hobsickle describes.
He installed a Turbine Tech frame brace and it was much, much better.
http://www.turbotuningturbinetech.com/en/products/swift.html
hobsickle
HS Science teacher
Jittney
Jun 18 2012, 11:46 PM
In my own case, the front wheels were 1/4 inch wider at their front than at their back. When both wheels were firmly in contact with the road their pulls cancelled each other (and they just wore the tires), but when you hit a bump the one with the better road contact would pull until the other wheel regained road contact. I adjusted the tie rods until the tape gave equal measurements front and back and the pulling on bumps (and excessive tire wear) went away. As an added bonus, the fuel economy also instantly jumped from consistantly 36 MPG to consistantly 40 MPG (it's a 4-door automatic).
Edited by hobsickle, Jun 19 2012, 05:16 AM.
Jittney
Nice fix!
Congratulations on the increased mpgs :)
hobsickle
Jittney
Might take a look at DIY alignment: http://www.lightweightmiata.com/geo/alignment/ :-/
