| check engine light intermittent | |
| Tweet Topic Started: Jun 9 2012, 12:10 PM (2,510 Views) | |
| Bad Bent | Jul 17 2012, 01:26 PM Post #46 |
Just for giggles, have you checked to make sure the bulb is firmly connected to the socket?
| Michner | Jul 17 2012, 02:05 PM Post #47 |
I think I may have the same sort of problem. My check engine light comes on at high rpm or highway speeds only, and once it comes on it seems to use an insane amount of gas. I jumped the terminals to see the code, but it only reads 12,12,12,12,12 over and over. Never anything else. The weird thing is it comes on, but will not return once the car is restarted until i hit highway speed or high rpms. Sometimes it doesn't do it. Matt... |
| djangomozart | Jul 18 2012, 11:39 AM Post #48 |
BB - Yup . |
| djangomozart | Jul 20 2012, 12:27 PM Post #49 |
Check engine light mysteriously went off and has been off for several days . It's raining today, but yesterday, it was dry . Dunno why , any guesses ? |
| Bad Bent | Jul 20 2012, 03:55 PM Post #50 |
Well, if we go back to the #1 post: "Autozone's guage said the aft 02 sensor is the problem. It's the spliced kind and all the connections are good . Didn't drop it . I don't wanna just buy another one and do it again. Anybody got some ideas ? " I'll add my story. My CEL came on on my 1991, The Filthy Beast, and it was the Code 13 for O2 circuit. I cleaned the distributor posts and the code went away and later returned but it would go away at higher rpms. It was the distributor cap. We got the Wife's '96, Goody Two Shoes, and it had the dreaded P0420. I know this because I spent about $30 on an ODBII code reader off eBay. I cleared the codes and about 2 days later it returned. I did it again after cleaning the distributor and plugs. and finally I bought a new catalytic converter and the code went away and did not return. Maybe 4 years later the light comes on. Could be the Cat. could be the sensor. I replaced the sensors, light stays on. The Cat. does not smell or make noise. So I unscrewed the 2nd sensor and plugged the hole with an old sensor. Wrapped the sensor in foil and secured it in the right front bumper area. I'll deal with it when I have do do inspections. If it is off I would not worry about it.
| djangomozart | Jul 21 2012, 06:07 AM Post #51 |
EZ for you to say , you ain't a worry-wart . JK . Now it's time to have the jalopy inspected before some other issue pops up . Thanks again for all your input BB . Oh, by the way, what kinda mileage you get with the hopmobile ? |
| djangomozart | Jul 21 2012, 06:43 AM Post #52 |
and bake yourself a cake today and dive in . Hava heluva day . P'z |
| Bad Bent | Jul 21 2012, 06:15 PM Post #53 |
Thanks djangomozart I dined on apple fritters for breakfast and chocolate mint ice cream for lunch. Apples are good for your health. Not sure on the gas mileage lately (with no complete fill-ups) but on long trips usually 55-57 mpg, probably 48-50 around town on E0 with some gas saving techniques and coolant preheating. |
| djangomozart | Jul 23 2012, 09:13 AM Post #54 |
Chia-z |
| djangomozart | Jul 25 2012, 10:15 AM Post #55 |
Light's still off so I'll count that as a victory, nah ? |
| Bad Bent | Jul 25 2012, 06:50 PM Post #56 |
| djangomozart | Jul 27 2012, 07:10 PM Post #57 |
Oh, one thing I didn't mention before, I timed it by ear, then retarted it a lil and Boom, light went out. |
| djangomozart | Aug 4 2012, 11:05 AM Post #58 |
decided I'd make some time and pass 2 cars on the straight-away by dropping it into 3rd and flooring it . Lil 1 litre easily passed 'em on a slight incline. When I checked the speedo after making it past the 2nd car, I was going 65 . I don't know why I threw it into 4th, but 5th came right after. ...... that's when I noticed the light came back on , @#$& . On it came again when I left work, but this morning , no light . Any ideas gear-heads ? |
9:40 AM Jul 11
