Noise from front end
Topic Started: Jun 12 2012, 12:26 AM (1,245 Views)
Jimmyjamx22
So it sounds like a brake squeak, but everything has been changed, Calipers, Rotors, Pads, even new fluid. still getting the squeak noise, starts at about 10mph, and goes away under 15mph when slowing down. and its a constant sound of squeak , kinda like the noise your brakes make when they need to be changed. i just cant pin point the noise. its more prominent on the driver side, but can barely hear it on the passenger. Anyone else have this issue? been scratching my head at it for a long time. haha
undgsx-R
Self Certified Garage Mechanic
If you jack it up and spin the wheel can you hear it?
Jimmyjamx22
undgsx-R
Jun 12 2012, 12:27 AM
I will have to try that when i get home. At work now. thinking its a wheel bearing?
crankcase
I would vote for wheel bearing.
Jimmyjamx22
So i got my new wheel bearings in, but i noticed there isn't a dust shield on them. Either one. Is that how they are supposed to be? Or am i supposed to reuse the old ones?
Already repacked them with mobile 1 synthetic grease. Also how do you tell which side goes in what way? they look identical on both sides, actually they are... so that confuses me lol.
Looks like there's supposed to be a seal on each side. :hmm
http://www.genmotorinfo.com/FullImage.aspx?ccId=455849523&ppId=283668712&ppInfo=1995-2000+M%2808%29%2cDrive+Axle%2fFront%2cLP2%2c+1.0L%2c+3+Cyl+ENG+-+SU06025
Jimmyjamx22
that picture makes it look like they are separate from the bearing itself, like they are there but not part of the bearing assembly. hmmm head scratcher for sure.
Jimmyjamx22
Bearings where shot. And everything was messed up. When we got the bearings out all you could hear is a scratching noise when you spun it. haha.
Also, My 96' bearings do NOT come with seals on the bearings them selves. Bearing seals are seperate.
Inner Seal part number - 710394
Outer Seal part number - 710175
Just so people know.
djn98metro
Where did you order your bearings from?
