Tires?
Topic Started: Jun 23 2012, 03:15 PM (1,789 Views)
Driver1337
Where can you get 185/75 by 13 tires?
Eric J
Formerly CEJ93
Tirerack.com offers a couple of 185-70-13s.....I know you are asking for 185/75/13 but thought I'd show you those anyway....
http://www.tirerack.com/tires/TireSearchResults.jsp?width=185%2F&ratio=70&diameter=13
Discount Tires Direct offers a few in a 185-70-13
http://www.discounttiredirect.com/direct/searchTiresBySize.do?sw=false&cs=185&ar=70&rd=13
Shinrin
Walmart most likely.
Why such a tall tire? I normally run P155/80R13
mikee66
costco for bridgestones, 65k warranty, life tine rotation and balance, nice ride so far have 9k on a set paid 280ish in may
craftsman1234
Jun 23 2012, 07:27 PM
Will this size tire from a 94 swift fit a 94 Metro so I can get 13' tires?
clarkdw
craftsman1234
Oct 13 2012, 10:42 AM
Yes, just get bulge nuts for the 13" wheels on the smaller 10MM studs. Stock steel wheels will work ok. Aluminum aftermarket may require longer studs.
http://www.ebay.ca/itm/ATV-16-Black-Lug-Nuts-10mm-x-1-25-Fits-Most-Models-/350298613663?pt=Motors_ATV_Parts_Accessories&hash=item518f6ca79f
craftsman1234
So If I get the tires and wheels including the stock bolts from the 94 Suzuki will I still need the Bulge Nuts?
Edited by craftsman1234, Oct 13 2012, 09:30 PM.
clarkdw
The stock bolts from the Suzuki are 12MM and require drilling the hubs and rear brake drums to install. The nuts alone will not fit the original 10MM studs the Metro has.
Edit: Unless you change the bolts then, yes you still need the nuts.
Edited by clarkdw, Oct 13 2012, 10:22 PM.
craftsman1234
clarkdw
Oct 13 2012, 10:21 PM
Got it thanks!
rjsdotorg
R E Member
Gorilla bulge acorn nuts
http://geometroforum.com/single/?p=407094&t=4084894
91 convert
I run the same size on my 91 vert. Can you tell me what I need to do to calculate proper mileage?
