Oil Leak Help; Engine oil leak
Topic Started: Jul 11 2012, 12:53 PM (764 Views)
Michaelt93
Hey guys and gals, My '95, 3 cylinder Geo has always been a big oil burner. It's has just recently gotten a lot worse however and I believe my MPG has dropped consequently. I'm looking for a website with some diagnostic and fix-it-yourself videos.
Please and thank-you!!
96Geoman
Hi Michael,
Can you describe the problems you're having?
Michaelt93
You've found it. Welcome!
You probably need an engine rebuild.
Michaelt93
Well I drove just under 400 kilometers the other day and went from 3/4 oil to the fill line. There is oil all over the engine and the under side of the hood. It was even dripping off the front end of the hood onto the bumper. This trip used to cost me about $20 in gas. This time it was about $30. Please help :(
Michaelt93
Jul 13 2012, 10:29 AM
Dang! :smackface That's quite a leak! :die
With a leak that size, I would think you should be able to see it by opening the hood, looking around, and giving it a couple revs. :hmm
If it's spraying the hood, and dripping onto the bumper, I'd take a close look at the oil sending unit. :news That can be a nice little oil squirt gun when they fail. :shake It's right next to the oil filter.
Cam & crank seals can be suspect too. :hmm
You may have to resort to degreasing the engine bay. :gamerz might make it easier to identify the source. :thumb
Michaelt93
Okay, I'll start with degreasing it then trying to pin point the source
96Geoman
Several places to check,
Make sure the oil cap is not cracked or broken (I forgot to put my oil cap back on at a gas station. Within a few miles, the engine sprayed oil all over the bottom of the hood)
Check the PCV valve connection, make sure the rubber tube is not cracked or split.
Look at the bottom of the dipstick tube (there's an O-ring that goes at the bottom of the tube) The top of the dipstick tube should fit tight.
:gp
My engine sprayed oil like that also when the PCV and "Y" tube clogged blowing out the cam seal. An easy fix in my case as the cam seal could be pushed back in place and it sealed. Now I'd spread a thin layer of RTV around the outer edge and push it back in place. To replace you'll need to remove the timing belt and cam gear.
Posted Image PCV valve location.
myoldman2
wait til your problem gets around you will have all the advise you need , and all of it will be good
Welcome to the FORUM you pick the best place to come for help :congrats :drivin
:thumb :wub:
MR Bill
Welcome to GMF
Michaelt93
Thanks for the warm welcome!
So I think I've isolated the leak. I believe the seal around the oil pan is blown and is leaking oil which is being picked up by the timing belt and flung onto the hood where it then drips down over the whole engine. I will replace the seal and see if that does it!
Thanks everybody, I'll let you all know how it goes.
Michaelt93
still leaking :(
3220onr
Valve cover gasket?
Cam and crank seals are the most likely area for a leak of that magnitude.
randyrandy
^^^ ...what Woodie said. They could make you think it was the oil pan :smackface , but it was up above. :O
Edited by randyrandy, Aug 4 2012, 08:08 AM.
