Growling, metal-rubbing noise on left-hand corners.
Topic Started: Jul 14 2012, 07:57 PM (644 Views)
GeoJeb
Seemingly from the right rear of the car.
I had installed new wheel bearings on the right rear
wheel only a year ago. I read several wheel bearing
threads on here, including one post where the Metro
owner at first suspected the exhaust rubbing. But I believe
he later confirmed it was indeed the wheel bearings.
I did check my exhaust and it seemed fine, hardly
wiggled, all rubber donut mounts in place on the muffler.
So I changed my wheel bearings on my right rear wheel
today. The old ones seemed okay. But I changed them
anyway. The test drive resulted in the same noise. So
I crawled back under the car and pushed hard with a
hammer on the exhaust closer to the midpoint of the car.
This time I noticed it indeed contacted the A-arm (???) thing
on the rear wheel. I safety-wired a thick piece of rubber between
the two and took another test drive. Noise all gone.
So it isn't ALWAYS the rear wheel bearing.
I hope this helps someone avoid my mistake.
The bright side is that you have new wheel bearings in the right rear and they should give you many miles of service!
georandy
Hmm, maybe that's what I hear. Thanks for the post.
